The end of last winter and early fall when temps were colder I was getting a CEL intermintenly when I believe system went into closed loop.
I get the following Memory codes:
� 172 & 176: Front and Rear O2 sensors not switching, system is or was lean.
Before I replaced both O2 sensors I checked the best I could for any vacuum leaks. Sprayed cleaner around U/L intake gaskets and PCV hose to see if I could notice a RPM change. No difference. So I decided to replace the OE sensors (3 wks ago) hoping to eliminate the constant memory codes I have been getting. Even hooked my scanner while driving after swapping out sensors to read data stream. The CEL light came back on while driving( 4 days later when temps started dropping) and then goes off again w/ the same memory codes. I get a slight uneven idle at stops and while at highway speed I can feel a very slight buck/jerk. Once the engine reaches normal operating temperture, the light goes off and I will not experience any drivability problems. I only experience the CEL and a minor drivability problem after the car has been sitting overnight or a long time when the temps go below 40 degrees. It seem if I warm up the engine for 10-15 minutes before driving, everything is normal. But if it is cold and I start right out I can "feel" the CEL about to come on before it actually does.
If there is a slight vacuum leak, why are the problems only happening during cold weather? I am sure others have had the same scenario w/ their Duratecs. I have yet tried to clean the MAF w/ electric contact cleaner. I have read where this may cause problem if it is dirty. I can also hook up my fuel guage to measure the psi, but I feel if it was a fuel delivery issue, I would be experiencing this problem all the time.
Now with constant colder temps, I do not feel like getting into anything deep in a cold garage. I just want to know what the culprit is that is making my brand new Bosch O2 sensors seeing this lean condition.
Any insight to this air/fuel problem would be greatly appreciated!
1995 Mercury Mystique LS OBD1
2.5 L Duratec ATX- No modifications
70,000 Miles w/ O.E. Water Pump
or
Replaced: VSS, Lower speedo-cable(2X)
Use: Mobil 1 5w30 and Techron Fuel Treatment.;) and
Mobil 1 ATF Change every 10,000 miles
