Posts: 536 |
Posted last week a couple times, still need help. Ill post a sound clip tomorrow. But here it goes. Doesent sound internal i.e. bearing, I think this because when I open the oil cap, the noise is the same, not amplifyed. I dont think it is injectors, dont know why I think that, When in the car it comes from the firewall area under the steering wheel, but it is harder to place when out side the car with hood open. Clutch possition has no effect on this "rattle". I looked at heat sheilds, they seem secure. I cant pin the noise to any pully inparticular. When the engine is cold, the noise is almost non existant. It starts at about 25g's rpm and is loudest thru 4g's, than it dies down but is still there till redline. Once the engine is at normal heat range it gets louder. At temp the noise will occur if you BARLEY push the gas peadle(before the engine gets any power, feels like a couple millemeters)and dies down once the engine starts to spin, then re appers at 25g. Doesent sound like tranny, but who knows. Thanks guys. Anything helps, at least makes me feel better. Oh yeah, no CEL's no power loss. Oh yeah again, after the engine has had a load on it, then no load and no gas, it is loudest, and sounds like it is fster than the engine is spining.
99' SVT #811 of 2760
Born on january, 12, 1999.
"This may have been his only shot at number one, but he just sucks on so many levels that I couldnā??t even let him win a contest of suckiness."
Posts: 536 |
could this be hubs(hope that is the right term)?
Posts: 1,016 |
If it occurs while at an idle, I don't think it's the hubs. Are you sure it's not the lifters? It's the only thing I can think of, other than a pulley. Pick up a automotive stethascope, and try to pin-point the noise.
Does this only occur in motion? I guess I should have asked that first.
~Eric
2000 CSVT Silver Frost: #942 of 2150
HID Projectors and Fog Light Mod, Optomized TB, MSDS headers
2003 Silverstone Z
Posts: 536 |
Yeah I realized that hub statment was stupid after I posted it. can I remove the serp belt or somtin to narrow it down, how?
Posts: 536 |
how can I tell if it is an exhaust leak, were should I start looking? one more thing, I got 74000 miles.
Posts: 5,345 |
Originally posted by Daddy Phat Sacks: how can I tell if it is an exhaust leak, were should I start looking? one more thing, I got 74000 miles.
Jack up the car, put on jack stands, start and then go under and try to determine if the sound is from the EGR tube (near the pre cat) or any of the other hoses near that. Note there are two other hoses which go to the DPFE.
Edit. Orifice tube is what it is called across the pond (for the EGR tube).
http://www.fordscorpio.co.uk/egrsensors.htm
1996 V6 ATX 96K miles
Posts: 536 |
would an exhaust leak be so sparatic? wouldent it be there at all times?
Posts: 10,015 |
Spun rod bearing it sounds like to me.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 536 |
iv had that before, doesen sound the same. And I dont have any cel's like last time, noise is much softer. I sure hope it's not.
