Posts: 2,116 |
My thermostat is on it's way to the great thermostat in the sky, but when I looked at where it is located I wondered what was ford thing?!?! Seriously....the thing is almost sideways and I will have antifreeze spilling everywere without draining the system. And How the heck do you get to the lower bolt easily? Any help on anything related to this would be great. Thanks
95 SE MTX
svt exhaust
intake
deer killer
Posts: 1,505 |
its all about feeling for it.
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 31 |
Ahhh...this is why I did a flush and fill before doing this, so that by the time I do my maintainance on this area that I can hope the new coolant/water mixture has busted up some of the old crud and a new flush and fill will have her ready for the last vestiges of winter and the first pangs of the summer swelter.
Posts: 2,408 |
Remove the air filter box.
Posts: 247 |
Originally posted by Rogerm60: Remove the air filter box.
ding ding ding ding!!! also remove the lower plate that holds your battery in for more room to work with.
Posts: 1,456 |
If that's a Duratec (I think it is) use some B'laster on that bottom bolt, it was tricky getting that one loose. Had to use extension and u-joint on the socket wrench. I imagine the waterpump needs replacing, if your engine is overheating. Metal or white plastic impeller. Drain part of the coolant, and cover up the trans below (the mlps switch is there).
Posts: 16 |
His info states "95 SE MTX". At least all 95-96 SE's are all V6, probably 97 too (but not sure).
But yes, I agree, check that water pump!
Posts: 5,345 |
Originally posted by dkusa67: His info states "95 SE MTX". At least all 95-96 SE's are all V6, probably 97 too (but not sure)....
When posting a request for assistance, the onus is on the poster to give the three main information, year, engine and mileage. The onus is not on those providing assistance/help to know that "all 95-96 SE's are all V6,". As soon as someone makes a general statement, there will be another who will post something different. Now, a SVT; you can take that to the bank that it is a Duratec (unless it has been modified).
Edit. Sticky on top of Troubleshooting Forum.
"When asking a question, please include all relevant details. i.e. engine type (2.5L Duratec V6/2.0L Zetec), transmission type (auto/manual), etc. We cannot help unless you are specific!"
1996 V6 ATX 96K miles
Posts: 21,197 |
Umm beatching about a t-stat?! 2 bolts to open the housing and it's right there. Takes 5 minutes.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 82 |
Aaaaaaahhh. Thank you Tony!! I'll add my mileage to my sig.
95 Contour, 2.0L, stick, 178K mi.
