Posts: 246 |
Exhaustive posts are hard to read but here goes
I had a shop that had done my catback and installed some cross drilled rotors install my headers, they finished today (started Sunday). First of all I called today to check progress and they informed me that they removed the radiator and the alternator?! The later seems to be a problem more on that in a minute. I called again for a progress check and it seems that they could not figure out the MIL eliminators. I instructed the "MECHANIC" based on the instrucitons inlcuded with the MIL eliminators (which i provided to them). Finally they finished and I picked up the car...
There was some smoke eminating from down by the firewall. They told me it was a little oil that was on the piping from their hands caused during the install and that it would go away in 20 minutes. OK I thought
So I am driving along and I start to notice that the interior lights are a bit dim but the headlights seem alright and the car is occasionally surging as I come out of second gear (could be my poor clutch work).
Soon the interior lights are too dim for comfort and I notice erratic almost dying idle, then the tach goes and the car just about dies. I am able to limp it to a parking spot
Current status:
The lights are working but maybe a little dim. The starter just clicks or will give a very weak slight turn of the engine. I am thinking they hooked the alternator up wrong or worse.
I guess feedback would be guesses.
I know in hindsight the shop may not have been the best but they had done simpler work well in the past and they had talked of doing header installs on other modern cars (IE a Maxima) so I though would I would give them a chance.
'00 CSVT Koni/B&G (New), SCA intake, 18 inch Falken Circuit Spec (gunmetal), CF hood, Headlights by Dan, Mirko, deleted front license plate/painted chrome ring. Headers/y pipe installed - TruBendz Borla system no Res and optimized TB. Getting there!
Posts: 3,637 |
[censored], tell them what happened, make them pay for the tow and fix. IMO if i ever have a shop work on my car i will be there the whole time watching what they are doing, i dont trust anyone enough to work on my car.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 1,746 |
Yea, def. get ahold of the shop and tell them whats up. Ask them who they want to tow it because they may have a deal w/ a local towing co. or have one of their own. But it should be at their expense. But make sure they fix it. If they had trouble with the install, they shouldn't have been doing it. But it is their responsibility to get it fixed by any means.
2000 Contour SVT
SF - #542 of 2150
Posts: 10,015 |
You don't need to remove either the radiator nor the alternator to install headers. The removal of the radiator might make it a little easier - but definitely not the alternator - oh well. Live and learn!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 4,292 |
Originally posted by Stazi: You don't need to remove either the radiator nor the alternator to install headers. The removal of the radiator might make it a little easier - but definitely not the alternator - oh well. Live and learn!
....removal of the radiator makes is ALOT easier.
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 5,600 |
Also, if you dont nab all the studs on bank 1 you have to drop the alt. to get the manifold out. Happened to me!
Black 1998.5 CSVT
Posts: 1,130 |
Originally posted by el' padrone: Originally posted by Stazi: You don't need to remove either the radiator nor the alternator to install headers. The removal of the radiator might make it a little easier - but definitely not the alternator - oh well. Live and learn!
AMEN! all the bolts are right in front of you and easy to remove. The only down side is having to diconnect your ac lines and losing all your refrigerant
Originally posted by Who the F are You?: does your family tree not have any branches on it?
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 4,292 |
Originally posted by RandyCSVT: Originally posted by el' padrone: Originally posted by Stazi: You don't need to remove either the radiator nor the alternator to install headers. The removal of the radiator might make it a little easier - but definitely not the alternator - oh well. Live and learn!
........ahhhh, i deleted the whole a/c system before i put the engine back into the car
Posts: 21,197 |
And why would you have disconnect your a/c? You can pull the entire engine with it zip tied out of the way. You can also remove the radiator with it in place.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 10,015 |
For the rear headers you do have to remove all the studs which you can do with a 5mm socket if they don't come out with the nuts as one piece. I always run a tap through each of the threads in the head before I reinstall the header as finding out you have a chewed thread after you just installed 5 out of 6 studs, totally blows!
AUSSIE ENDLINKS $70
