Thanx for the quick respond, the code I think is P0302 P303 and I remeber one of them is ineffeicent cat, I will ask my brother what exact it is. however,
if the coil do not have enought juice and if the exhaust is plugged, I can't explain how it can rev smoother after 4k rpm.
when the car start having problem, the first code came on was a bank 1 o2 sensor was respond slow, so I had changed it before I went to cali, 3000miles after I got back to Tx, the car got wrose and throw the P302 P303 misfire code, what else do u think it is happening from what I describle above, the only thing the I'm thinking of is that I might have low compression , but I don't know how can I blew the piston if it's daily normal driving. yes I have not change out the plug wire, but as I stated before, I would like to find the problem before I change those out. if the plug wire is the problem, then I will do it.
