Posts: 110 |
How much is the zetec final drive going to hurt performance in the areas of acceleration, trap speeds in the 1/4, and total whp? Reason asking is I was originally going the turbo route when I had the tranny built but the funds didn't allow it later on.
Posts: 1,746 |
Ask in the ZETEC threads!
2000 Contour SVT
SF - #542 of 2150
Posts: 7,100 |
Considering the "zetec" forum wouldn't know what their own final drive would do to a DURATEC (they don't drive a Duratec), I would think that this would belong in DURATEC performance (as it is a performance oriented modification.
'99 CSVT - Silver #222/276
Posts: 9,065 |
PM stazi or todd...they both have zetec FD's in their duratecs. I just had one installed in mine, but have yet to get the car running.
Posts: 9,602 |
The 3.84 FD will degrade acceleration in every gear.
They will not change your trap speed. However that still means it takes longer to get to the same mph. (see #1)
They will not effect true power to the wheels. They can/normally falsely improve dynojet numbers because of the way a dynojet calculates power.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 9,065 |
Originally posted by DemonSVT: The 3.84 FD will degrade acceleration in every gear.
But, if you are making more power than b4 (3.0L) and you found yourself shifting into 4th gear at the end of the 1/4 then you are getting some benefit. Also when racing from a roll...the diff laucnh characteristics and the ability to hit 60mph in 2nd should be of some benefit.
Posts: 9,602 |
Originally posted by MapOfTaziFoShoĆ¢ā??Ā¢: But, if you are making more power than b4 (3.0L) and you found yourself shifting into 4th gear at the end of the 1/4 then you are getting some benefit. Also when racing from a roll...the diff laucnh characteristics and the ability to hit 60mph in 2nd should be of some benefit.
You are confusing benchmarking terminology with actual real world performance.
You state that the 0-60mph may be quicker because the car can reach 60mph in 2nd with the 3.84 and stock redline (6900rpm SVT) {insert formula} 6900rpm with 3.84 & 24.5" tire = ~61mph
However you are failing to note that acceleration in 1st and 2nd gear will be slower because the gearing is weaker. That 3 tenths of a second you save from not having to make to 2-3 shift, during that small bench marking window, is basically going to wash with the slower acceleration of the first two gears.
Also if you use 10mph increments you will note that the 4.06 gears accelerate stronger to each respective 10mph mark when you factor in the shifting. Remember even if your 0-60mph is the same with the 3.84 gears your 0-50 is slower and 0-70 is much slower. (the 2-3 shift with 3.84's is between 60 & 70mph The 4.06's will just continue to walk its ass!)
You CAN NOT think about benchmarking times meaning a whole lot just by themselves. The placement of a shift point can significant skew those types of tests.
Racing from a roll. You still have 5% less TMF in every single gear. That means slower acceleration in each gear.
The only way a taller gear helps is if you have obscene amounts of power over a very broad powerband and can over power (literally) the losses caused by the weaker gearing. (there are formulas but I'm not typing them out) Turbo 3L's may fit that description but 300-400 wheels is really not "obscene" in my book. They do fit the very broad powerband and lower rpm powerband criteria though.
Also to add, the shift from 3rd to 4th at the end of the track is not relevant. The 3-4 shift duration does not cause any significant loss of acceleration ability in such low power applications.
Also any car trapping over about 95mph needs to shift to 4th regardless. That makes that a moot point for any car much above SVT levels.
2000 SVT #674
Posts: 718 |
If you do not shift into 4th in the 1/4 with a V6 in these cars then you have a very slow car! lol...Hell, I almost shift into 4th in the 1/8 mile with my Cougar and a 75 shot. If I had some traction in the first two gears I prolly would have to shift into 4th, but my cheap arse not buying some drag radials...that's a different story.
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 595 |
Do you think a roots style supercharger falls into this category? Something like the Eaton m90?
Black 1998.5
3L Oval Port
Full HMS Transmission
Lots of other stuff
Ressurected 06/14/06
Posts: 9,065 |
I did some research and saw that Rick as a zetec FD on his SC 3l...would that be obscene enough?
