The MAF sensor is between the filter housing and the throttle body.
Hard way but you can clean it better: use vise grips to remove the screws then you can clean it with direct spray. Just be very careful when removing, working with, and replacing, because the wires are delicate. Easy way: remove the air filter and shoot the cleaner through the screen into the little pitot tube where the wires reside.
The screws that hold the MAF sensor in the intake are security torx and they put some sealer into one of the screws to make it harder to get off. I have the tool (you can get it from an electrical supply house) and some extra screws so when I got it out I replaced the one with sealer in it with a normal one.
