Posts: 5,345 |
1996 V6 ATX 96K miles
Posts: 3,065 |
It is just attached and open to the tank.. sometimes pouring coolant in there, it comes out the hose... maybe it has a release valve or something.
Posts: 4,292 |
huh?, i've never seen that on a tour,actually your coolant tank looks different than mine,i have two hoses coming out of the front of the tank,it looks you just have one up top..
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 6,910 |
Originally posted by tour96se: huh?, i've never seen that on a tour,actually your coolant tank looks different than mine,i have two hoses coming out of the front of the tank,it looks you just have one up top..
its a post 98 thing
- 95 Mystique LS - Zetec/5spd
Posts: 51 |
its just a overflow hose... and good luck it will never get white again, it will be yellow even if you get the funk out of the inside
2003 Cobra - not stock... 496/525 rwhp/rwtq
Kenne Bell here and waiting to go on...
2000 SVT Contour - Very stock...not for long
Posts: 3,065 |
Originally posted by ugotbit: its just a overflow hose... and good luck it will never get white again, it will be yellow even if you get the funk out of the inside
Yep. Weird design, if it overflows it sprays over the engine.
Posts: 1,578 |
The best picture I have of mine. I'd try to find one on e-bay or a junk yard. Hard to believe it is still the original with over 100K on the clock
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
98 'Tour SE 24V 5-spd
149 HP @5900
148 LB FT @4300
Posts: 51 |
Originally posted by Matt R: Originally posted by ugotbit: its just a overflow hose... and good luck it will never get white again, it will be yellow even if you get the funk out of the inside
yeah.. the little hose is supposed to direct it to the ground, winds up going all over the belt
