Posts: 4 |
please help. I have a 97 contour w/bad engine. I was told that one from a 98 would fit, so I bought it. Looking at both, they have some differences. Anyone have any idea if these are interchangeable???
life's been good...so far!
Posts: 4,693 |
It would greatly help if you would tell us if this is a V6 or a 4 cylinder.
The short answer is that the V6 can be used but I understand that the 4 cylinder cannot.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 5,345 |
Welcome zoman.
1996 V6 ATX 96K miles
Posts: 200 |
Originally posted by zoman: please help. I have a 97 contour w/bad engine. I was told that one from a 98 would fit, so I bought it. Looking at both, they have some differences. Anyone have any idea if these are interchangeable???
Lower intake is different (97 is vac. controlled I think) just swap over everything that looks different from your old block to the new one, It will work.
98 Contour SE 3.0L 5-speed
SCT PRP, Gutted IMRC's, Fidanza Flywheel, Race Ported 2004 3.0L Oval Port, Zex 125hp shot, 70mm Mustang TB, 42Lb injectors,Walbro 255 pump, Traction Bars, Zeitronix wideband o2, lots of little things, 10,000K HID's!!
Posts: 1,505 |
Originally posted by Tony2005: Welcome zoman.
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 4,693 |
Originally posted by zrated: Originally posted by zoman: please help. I have a 97 contour w/bad engine. I was told that one from a 98 would fit, so I bought it. Looking at both, they have some differences. Anyone have any idea if these are interchangeable???
Only the 95 V6 has vacuum secondaries.
We still don't know if this guy has a V6 or a 4 cylinder.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 498 |
a zetec would require a new computer due to 98 having VCT and 97 not, but like everyone says, we don't know if you have a V6 or a I4..
96' ATX Zetec- stock
96' ATX Zetec- Modded
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Mystique Cluster/oil pressure
Getting repainted(in primer)
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 4 |
sorry for the screw up guys...its a 2.0L four banger.
Posts: 4 |
someone mentioned something about requiring a new computer...so if I can get the computer, is everything else gonna work? Thanx to all that replied...I appreciate the help!!
Posts: 4,693 |
No. There are a lot of differences between a 97 and 98 Zetec. It is more likely that you can use a 95 or 96 though.
Jim Johnson
98 SVT
03 Escape Limited
