#1448799 11/30/05 03:06 PM
Hoping you guys can help me out here, I have a math problem that I cannot figure out for the life of me! And I'm sure most of you guys will know it in a heartbeat...
"True or false? If true, give a justification (not just an example). If false, give a counterexample. Assume a, b, and c are natural numbers.
part 1) If "a" is a factor of "b" then GCF (a,b) = a
part 2) If GCF (a,b) = x and GCF (a,c) = x, then b = c "
Thanks if you guys can help out!
What is CEG the new math tutorial all of a sudden?
W
W
1.) false
If you look at #1, you can see that the greatest common factor is not necessarily "a". "a" could be any factor and there could still be a greater common factor.
2.) true
Since "a" is equal in both equatios and X is a GCF for both, then the only way that can happne is if b=c.
You can set up a couple of examples I think to prove it.
I <3 Math.
E
E
true
this one's not too bad if you think about it. think about exactly what you're saying when you say GCF - "greatest factor." how can "a" have a factor thats bigger than itself?
false
a = 12
b = 9
c = 3
now officially a troll, i guess. used to have a black 96 SE, until it broke down one too many times. now I'm hunting for a motorycle.
W
W
true
false
a = 12
b = 9
c = 3
whoa, I didn't read either of those right! I looked at #1 and I didn't see the part that a was a factor of b
#1 true
For #2:
What if a=6, b=3, c=3
Then b=x=c
It makes the two exactly the same equation, which doesn't seem right. It looks like they intend it to be two different equations, but the only time number two is true is if b=c. Maybe they're just trying to trick the student or make you think
So I guess they are both true in this case?
your explanations all make great sense! i don't know why i couldn't think of that. my mind just doesn't work that way sometimes, lol. thanks guys for helping me out!
true
false
a = 12
b = 9
c = 3
That's right, 1 is true and 2 is false. For 2, consider any three numbers a, b, and c that have a greatest common factor x. That does not imply that any of a, b, or c are the same number, although they could be. For example, 10, 15, and 25.
E0 Silver Frost CSVT #3095/6535 Alpine CDA-9851
