#1448020 11/30/05 03:07 AM
could a third gear grind be caused by poorly adjusted clutch or shift linkage. Just wondering.
99' SVT #811 of 2760 Born on january, 12, 1999. "This may have been his only shot at number one, but he just sucks on so many levels that I couldnā??t even let him win a contest of suckiness."
Highly doubtful. You have a 6 year old car. I'm guessing over 80k miles. Time for new synchro.
third gear grind could indeed be caused by a misadjusted shiftlinkage, but not by the clutch. if the clutch wasnt disengaging all the way it would cause a hard shift in all gears. on our trans 1, 2, 3 all have double synchros, so it probably is you synchro. i have a hard shift into second sometimes. but mine has 208000 miles on it so mine is almost definatly the synchros. try adjusting your cables first and if that doesnt change anything then you know its internal.
it could also be the a bent shift fork. does it ever pop out of third?
97 contour gl mtx front & rear upper strut tower braces 19mm bat sway bar Koni struts w/GC knockoffs
And it would have hard engagement in all gears, as you went on to state, if the cables were out of alignment. Haven't heard of anyone bending a shift fork in an MTX-75.
almost 80k, but the tranny has less than 20k. It was rebuilt with the "revised" one snap ring syncro, from what I can gather. Just hoping. Thanks sirs.
Uh oh! That's why. Single style instead of the twin. Go to any Focus forum and ask them how great the revised single is. Who told you to put that in? A dealer? Take it back!!!!!!!
thats the only part my former half assed tranny shop could find, anywere.
Because Terry bought them all up.
i havent either but nothings impossible. shift forks do bend or break. bot common
