#1445757 11/27/05 06:24 PM
Since its been getting cold out side, when i first start my car it will rev up and then go down to idle (like any other car).. but when it revs, the engine ticks really bad. But when it goes to idle it goes away. It only lasts for like 1.5 seconds. Whats going on?
Mike 98.5 Black CSVT #5291 of 6535 (Oo.<xx>.oO) o xxxxxxxxx o
#1445758 11/27/05 08:20 PM
feul injectors ticking???????
Originally posted by Who the F are You?:
does your family tree not have any branches on it?
99SVT 235hp @ 6550rpm 212tq @ 5350rpm
#1445759 11/27/05 09:24 PM
F
F
Maybe the chain rattles. Check oil level, make sure it's not thick (racing) oil too. I use 5w-30 Mobil 1.
#1445760 11/27/05 09:28 PM
My car has done that for a few years now. It is more pronounced in the cold, and also as I close in on an oil change....Car runs great still
1998.5 Silver Frost SVT #4978 of 6535 160,000 miles and still going..
#1445761 11/27/05 10:14 PM
Are you using synthetic oil? The synthetic oils flow better when cold.
#1445762 11/27/05 11:06 PM
TYPICAL clattering of timing components upon initial startup. low oil pressure at first.
better anti-drainback valve's HELP..
#1445763 11/27/05 11:35 PM
F
F
Like in the Motorcraft oil filter FL820S.
#1445764 11/28/05 06:29 AM
O
O
Ours makes that sorta clicking noise but I only hear it when the engine idles, don't remember if I've ever heard it above 1500rpm.
Right now if you push ours past 3000rpm or so, the CEL comes on *has to get that EGR valve cleaned out heheh*
1995 Mercury Mystique 2.0 (125hp of FURY!) 2006 Chrysler 300C 5.7
