Posts: 172 |
well I paid the extra $100 core charge to keep my old engine and I planned on letting him put the SVT topend on the couger 2.5l but should I make him put the pistons in too? thats gonna require alot more work, or maybe see if he'll fab up some custom headers instead,will he still have to pull the engine back out?
1998.5 csvt black #4686/6535 FASTER THAN A SPEEDING TICKET
Posts: 1,047 |
Why would you do that? The block and internals are the exact same,the real differences are the cylinder heads,intake,larger TB,exhaust manifolds & the quasi dual exhaust. It's all basic bolt on stuff that gives you the extra 30hp. Just get all the required SVT parts you need,and you're back to SVT spec,the only difference is that you won't have the original block that came in your car,and nobody would be able to tell otherwise.
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's
'89 Mazda B2200 - Under Construction
Posts: 7,100 |
re: why would you do that?
SVT cams ARE different..
'99 CSVT - Silver #222/276
Posts: 172 |
The certified SVT dealership in my area says the pistons are different also, compression ratios are not the same???
Posts: 1,047 |
I dunno...just from what everybody has told me,the blocks and internals are the same. Anyways,if I'm wrong I'm wrong,but if I was in your shoes I'd just source the parts I need and not need to worry about pulling the motor again.
I don't care,I don't like Duratecs anyways. PITA engines to work on. That's why I'm building my Zetec instead.
Posts: 4,693 |
The pistons are slightly different. The compression ratio change isn't much. On the 98 and early 99 it goes from 9.8:1 to 10.0:1. On the late 99 and 00 it's more, from 9.8:1 to 10.25:1. The rise was to help compensate for the slightly smaller bore on the later engines.
Under the circumstances of getting a low mile replacement engine for such an exceptional price, I would be inclined to suggest that you swap the SVT pieces from the old engine over and call it close enough. You will end up with most of the horsepower that you had before but have a fresh engine. If you hold out for an SVT engine, you may end up with an engine in much poorer condition.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 21,197 |
Way too much work to swap all the internal SVT stuff into the regular 2.5. Much easier to just swap a correct motor in. I would be irrate if I had that happen. I'd everything necessary to get it corrected.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 584 |
Originally posted by guitarman19853: OOOOKAY.... how the heck do you go to get an engine swap and then NOT OPEN THE HOOD AND LOOK AS SOON AS YOU GO TO PICK IT UP??????? That would be the FIRST thing i did.
Go back and tell him to put the right engine in.
That's just what I was about to say. Who drives out of the shop after getting major work on the car without at least looking under the hood?
E0 Silver Frost CSVT #3095/6535
Alpine CDA-9851
Posts: 970 |
Yes. And just out of curiosity, I'd like to see pics. I'm not doubting you, but I think that would make a neat OWNED pic.
98 GL sport (V6 MTX)
The Durable Duratec? - (DMD, Metal impeller WaterPump, Synth & Stinky in the tranny)
Posts: 624 |
Originally posted by RTStabler51: ...Mustang LX's have the same 5.0 in'em as the GT.....
My 88's had different throttle bodies that was the only thing that I saw though! Both were stock, But the GT Had the HO badge in the center & the LX didn't!
I don't "mod" I just fix what breaks!
98 CSVT #2527 T-Red (Limping)
98 CSVT #2228 T-Red (Donor)
98 SE Sport ATX V6 (Running again)
If swimming is good for your figure, explain whales to me!
