Replace the mast, check e-bay
antennna or Ford dealer, teamfordparts.com, etc. The toothed belt is worn at the end, if it retracts when you push down on the tip. You may need to check for a broken piece in the housing, compare the new beltlength to the old one, if it's the same, Ok to put it in.
