Posts: 43 |
I got no heat. It slowly comes on. Fan works. It was working great up until last night. I don't see anything coolant coming out of the water pump. So I'm thinking thermostat? Em I right or is there something else to look for? Thanks.
1998 Contour 1500,000+ kms
Power Package Everything
Aluminum Alloy Wheels
2.0L Engine
Canadian Eh?!
CEG road warrior
CEG road warrior
Posts: 17,248 |
Replace the thermostat....sounds like it is stuck open.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 160 |
Yes. It's probably a thermostat. My moms taurus had the same problem. It would give heat but it would take like an hour. Changed the thermostat, blows heat instantly.
96 Contour GL 2.0, ATX "Herman" 101K
"A Clean zetec is happy zetec"
Posts: 4,693 |
If the temp gauge comes up to where it usually does, it is not likely the t-stat.
If it is not the t-stat:
You may have a restriction in the heater core or the hoses to it.
You may have a problem with the blend air door not swinging to the heat position.
You may have a problem with the temp control so that nothing happens as you turn the dial.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 1,456 |
If the engine temp seems high, the waterpump could be bad.
Posts: 4,693 |
Jim Johnson
98 SVT
03 Escape Limited
