I going to show my inexperience here with my Contour. Boy did I goof myself up.
I tore apart everything to adjust the timing again. Put it all back together and low and behold, nothing. It seemed that the car was running on 3 not 4. So I started to check fuel injectors. #4 was not working. It was not getting any power to the injector. I started trouble shooting it and ended up at the PCM. Something was fishy though, the wire colors on #4 weren't matching the schematic! I had been messing around there and found that the plug on the injectors is the same plug on the Camshaft Position Sensor. I had them swapped.
Needless to say she is running like a kitten and I now have no codes!
Boy do I feel dumb! Be careful not to do that!
