Okay fellas, here's an interesting one. Just got a 98 Contour SE. Knew it had trans problem. Symptoms: NO BANG SHIFT--just a long wind up and then when letting foot off gas, seems to skip over 2nd and into 3rd (AT FIRST
). 2nd gear IS in there somewhere because when coasting if I move the selector from "D" to "2" I can feel it catch but if i apply throttle I get just a little jerk and then it seems as if I'm in neutral.
THEN HOWEVER when the OD light starts flashing ??? (in a relatively short period of driving) it seems to shift much more smoothly with much less wind up out of first, and it may even be going into 2nd (its so smooth i'm not sure)
Performed the "big 3". Fluid change 4X (it was so dark i thought i was changing motor oil)(but it didn't smell burned???) TSS - got away lucky with only 2.5-3hrs, and MPLS. No jumping or malfunctioning speedo. So I thought, okay, going to Autozone even though "check engine" is NOT on, gonnna find a litany of codes with things burned out, slipping, and not pumping. NO CODES-----"PASS"
NOW WHADDAYA MAKE OF THAT???
