#1440882 11/21/05 01:14 AM
LCX Offline OP
96 with a 2.0 Zetec , STD tranny
Symptoms are -
Slightly rough idle at times
Performance is great under hard acceleration
When in slow moving traffic trying to keep a constant speed (very light application on gas) the motor surges (almost like its hunting)
It makes rush hour driving a pain,it's not excessive but noticable at most speeds but only on very light application of gas pedal.
Changed so far -
New IAC
New MAF
New Plugs
New Air filter
New Fuel Filter
Help! it's getting annoying to the point i hate driving it
Thanks
#1440883 11/22/05 03:05 AM
LCX Offline OP
One other thing i have noticed now that the weather has turned cold . First thing in the morning th car starts no problem , the rpm's rise to approx 2000 rpm and gradually drop to 1000 and then it sputters to a stall , it restarts with no problem and maybe does it once again and then all is back to the sysptoms described above. It does not do this when the car is warm/hot.
Thanks ....... help or suggestions will be greatly appreciated
#1440884 11/22/05 04:25 AM
Put a bottle of HEET or fuel stabilizer in the gas tank.
#1440885 11/23/05 12:07 AM
LCX Offline OP
Thanks for the response
i have been running it on Sunoco 94 and have also tried octance boost/stabilizer but i have the exact same problem.
Any other help is appreciated
#1440886 11/26/05 02:55 AM
