Why do you need to connect it to the stereo system? It's gonna be next to impossible unless you get a mini audio mixer and use an external audio amp, 'cause you can't just connect the scanner and the stereo to the speakers at the same time. You'd want to run the line-level audio from a head unit and the audio output from the scanner into separate channels of a mixer, and then run the output from the mixer into your external audio amp.
If your scanner has too small of a speaker, you could just get a larger one for a two-way radio or CB and mount it under the dash or something. Another thing you could do is use the front speakers for the stereo and connect the rear ones to the scanner (after disconnecting them from the stereo.)
Marty
98 SVT, Black, No. 786, May 7, 1997.
K&N, MSDS, Xcal2, Tint, Antennas, Big Gulp(R)-Sized Cupholder, Rear Dome Lt., Koni/Eibach, DMD, Pre-98 Sails, Brake Cooling Deflectors, Sidemarkers, Etc.
147K+ Miles
"Get the Door - It's GrooveNerd!"
