V
volcar Offline OP
V
I have been experiencing a problem with my brake lights where the left or right does not work only the third (high mounted) one works & after numerous checks I discovered that the cause of the problem was the connector for the rear turn/stop light circuit attached to the Combination Switch. The connector has a defective connector on the 29S (O/Y) power lead I had to stuff a piece of wire behind it in order to get the stop lights to work.
It appears that Ford is using inferior wires & connectors hence the recall on the engine wire loom. As a consequence of this problem & the temporary fix to my rear turn/stop light circuit problem I am using this medium to ascertain whether anyone knows where replacement connectors for the ΓΆβ?¬Λ?Tour can be obtained.
F
F
Try your Ford dealer or maybe www.teamfordparts.com, Bill Jenkins. Make sure the contact is snapped into the plastic plug, but it sounds like the gripper just got weak.
