Ok, stupid question. Now, I had good oil pressure so it shouldn't be a problem but.......
I'm just wondering IF I should happen to jump a tooth on one of my cams, how far off could I be before I start getting interference? 1 tooth, 2 teeth?
I'm asking because I was at the dyno last night and they had the car running fairly decent. But on one of the pulls, he said it just suddenly stopped making power around 6950 with the rev limiter set at 7100. It sounded like he bumped the limiter. Now, it won't even idle quite right and doesn't rev properly. It's got what seems like a bad miss in it now.
I tried changing plugs (they put coppers in it) back to dbl plats to no success. I'm wondering if it might be the coil gone bad or possibly something in the cam/timing chain system.
I'm at a loss.
