Anyone here use an SLA (sealed lead acid) battery on their car? Reviews?
I know dyna batt is one brand of sla's marketed towards performance cars. The neat thing about em is that they are only alittle bigger than a motorcycle battery but, put out as much if not more cold cranking amps as a regular auto battery. They typically last longer, and as a big plus they can weigh as little as acouple pounds depending on application! For our cars probably 10-14lbs not bad!
Also they aren't really all that expensive a Odyssey PC680 (a dyna batt is a rebadged odyssey, which would suit our cars) runs about $77. Now that's more than your cheapy duralast but, for a gel/dry cell that weighs 1/4 of your regular car battery! I'd say it's well worth it, for the weight savings! And they work very well in all climates.
learn more at:
http://www.stealth316.com/2-dynabatt.htm
