#108925 11/06/01 06:06 PM
1
1_dup1 Offline OP
1
Terry - I've got questions about our fuel systems that probably only you would know. On the 95-98 tour's Ford used a nippon denso side feed pintle injector, then in 98 went to a bosh disc style. Was this just another round of decontenting to use the cheaper injector style - or are there some emisions benefeits to the later setup?
From what I've read, for all but all out high rpm / high performance applications the pintle design gives the best spray pattern & atomization.
Also - three of us have noticed our side feeds run at about 31 psi (new fuel filters, FPR and in one case a new pump) which seems low compared to the standard 40ish I think most injectors are rated at. Any ideas why this is - maybe used an off the shelf bigger than needed injector and then just turned down pressure to suit the needs???
Also - do you know if both designs were saturation systems, or were the side feeds peak and hold?
I'm now thinking now that an early tour switching to a 19# mustang bosh disc injector would not really be an "upgrade" from our pintle set ups, especially if we leave fuel pressure at 31 psi - I think we'd only end up with about 17 psi out of the 19#ers. However, if 31 psi really is the norm there is lots of room to up pressure for more fuel delivery (if needed).
#108926 11/06/01 06:23 PM
The pintle is regarded as the better injector re atomization.The pressure is 'adjusted' by the manifold vac re regulator.The high number is the max rated op pressure,above that they will 'dribble' in the closed position.Have to watch oversize injectors,a large injector with a normal/low pressure will give very poor spray pattern and atomiziation.Have to maintain the pattern and 'mix' with the incoming air or the benifits of larger injectors in an upgrade are lost.I think they were 'peak & hold'.regards TH
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#108927 11/06/01 06:32 PM
1
1_dup1 Offline OP
1
thanks
