H
huacat Offline OP
H
My 98 Contour SE (6 cylinder 2.5 L) has 65000 miles on it. But a dealer told me after an oil change that there are some small tiny cracks on the edges of the inner side of the serp belt. He reccommended replacing it ($100!). The service manual did not say you need to change the belt at at only 65000 miles. But Murrays Auto parts store has it for only $11 for 1 year waranty and $17 for lifetime warranty. Did anybody repalce the belt by themselves? Do you need special tools?
Thanks!!!
huacat
While cracks across (rather than longitudinal) are acceptable, 65K and 7 years is a long time for the serpentine belt.
If you can see cracking on the inner side of the serpentine belt, I'd replace it. The cracking will soon be followed by small missing chunks of rubber.
Yes, it's not a difficult DIY job. The biggest problem is getting access to the tensioner to loosen the belt. I was able to squeeze a standard ratchet in there on my car. There are also tools like this:
http://www.autobarn.net/lis57600.html
1995 Contour GL V6 ATX T/C 1986 Mustang GT 5.0 2000 Windstar LX
But it probably does say, or at least the Haynes manual does, to inspect it every 10-15k and replace it if it is worn or cracked.
Definitely do it, it's fairly easy (or cheap) preventive maintenance.
'95 Contour GL, Zetec/ATX Repairs: * wheel bearings * sway bar stop * CV joint * alternator * shift interlock * heater tube * VSS * tensioner * ingition coil * wire harnesses * ball joint * Why do I still love it?
How about 7 years and 155,000 miles?
Getting my alternator replaced, and I gave the garage the serpentine belt I've had laying around to put on while they're at it.
98 Contour V6 MTX, T-Red, 150k mi. Pic SVT Dual Exhaust, KKM Intake, Donnely Mirror, Dension DMP3 Player w/80GB of MP3s, Wheelskin 95 F-150 91 Mustang GT 06 Honda Shadow Aero
