Changed the oil (and filter) day before yesterday and put in only 4 quarts and shows on the dipstick that its about a quart over?!? Started it up...ran it, then checked again and it's the same thing. Possibility that the stick doesn't belong to this car? Could someone possibly get me a measurement?
Thanks
1999 Contour SE 2.0L ATX 104k miles
Probably not. I'd check in your owners manual to see how much oil you should put in, and not really rely on the dipstick. For my Zetec, it says 4.5 quarts.
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
That's what it says with mine also...4.5 qts. The thing that blows my mind is that it shows it being a QUART HIGHER than capacity. I usually have the oil change done at a 'quick lube' shop as I have nowhere to put the old oil. I decided to do it myself this time since they put the wrong grade of oil in last time. This makes me wonder if I've been running the car a half quart low since I got it two years ago
YIKES!!!
good thing you caught that!
