#1435843 11/14/05 11:14 PM
Couldn't find anything remotely related to this, but here goes:
Lately after driving around for a little when I push in the clutch, the RPMs either stay where they are or sometimes they surge to around 3 or 4 or even today around 5k RPMS. What gives? Is there some sort of sensor that is going bad? is it tranny related? Am i screwed? Any help is appreciated. Thanks in advance.
-Aaron
1998.5 SVT Contour (now thumpin') 1996 Ford Thunderbird LX Sport (running and going through gas like a mofo!)
#1435844 11/15/05 12:48 AM
#1435845 11/15/05 01:21 AM
ahh, thanks. i've actually had that sitting in my glove box since i got the car last year. now i can put it to use. thanks.
#1435846 11/15/05 01:34 AM
Z
Z
I have the same problem. I did the throttle hang fix, and went with the larger diameter hole in the center and it seemed to drop off way too quickly. You had to almost sorta double clutch it to keep the rpm's up inbetween shifts, even with the fastest shifts from the shortthrow it still dropped off for a rough reingagement. So I took it out for now.
Should I try a even bigger center whole, or whats the idea?
98 Black Contour SVT #1273 Born the 23rd of June, 1997
#1435847 11/15/05 04:36 AM
Originally posted by ZZCSVT:
..Should I try a even bigger center whole, or whats the idea?
This thread has some suggestions.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1014140&page=1&view=collapsed&sb=5&o=7&fpart=all&vc=1
#1435848 11/15/05 05:40 AM
Z
Z
I'll try one slightly larger than what i used, not sure, believe i tryed the 7/32's, ill double check that though.. go slightly larger and go from there. maybe I can find a good dia.
thanks
