SVT#873 Offline OP
Wanted to know if you PERSONALLY installed a QUAIFE Diff so I can get some pointers smile
Thank you Jeremy
"Sometimes I find pickle slices in the sheets."
"Suck fist Dr. Dork."
i wouldent even attemt this unless you are a certified mechanic, even then...
95 SE Champagne Mettalic
True Dual exhaust with X pipe and Redline mufflers
KKM Tru Rev intake
H&R Springs/KYB struts
Apex-i S-AFC
65mm Throttle Body
17" Ace Spades
4 Pt Racing Harness
Window Tint all around
New Engine @ 117k kilometers
G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass"
quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
Unless you have a manual including side load specs, and have done a diferential set up before, don't attempt this. Some of the cases require clearance grinding for the larger Quaife case as well. A basic Quaife set up will cost you 0.5 - 2 hours shop time depending on how far down your trans is disassembled when you deliver it to a transmission shop and if it requires any clearance grinding from what I've been quoted. Good luck.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
