I installed a Autometer Monster Tach today but don't have a clue what wire is the tach signal on a 95 SE . Can anyone helph me out?
0
depends on what motor...
Zetec: white/black wire at ignition control pack
Duratec: brown/yellow wire at ignition control pack
if you have a factory tach, you could get the wire behind the instrument cluster as well. Also in any contour, the wire can be found at the PCM behind the power steering resevoir. should be pin # 48
2000 Contour SVT Silver Frost #422 of 2150 - Nov. 18, 1999 1999 Mustang GT Black "Tell the Snap-On guy I went to lunch."
