#1433542 11/10/05 08:02 PM
My awsome glove box light quit working today and I replaced the bulb and checked every fuse in the car. Nothing seems blown. What else should I check for? I can not believe were the fuse box was! HAHA I had to press this black button and it folded down! WHOA, man this car is better than a 90 corolla!
Midnight Red 95 Contour SE 5 speed, fully loaded. kkm M.A.F. adapter w/ K&N ru-3530, single Magnaflow muffler w/ no res. 2.25" custom catback exhaust, grafite painted stock 95 SE rims on bfgoodrich touring T/A's, 35% window tint around.
#1433543 11/10/05 10:40 PM
Understatement of the year nominee!
Champagne 1995 Ford Contour LX R.I.P. - 7/11/06 V6 2.5L 24v DOHC Oversized System
#1433544 11/11/05 01:14 AM
Two more things to check. The switch, push it in and out to make sure the spring is working. The other is the dreaded wiring. Run a wire from the battery to the fuse or fuse to the bulb to see if which line is shorted.
#1433545 11/11/05 12:37 PM
Thanks tony! I'll try that today and see what happens!
