Posts: 110 |
I had the 97 contour parked over in this spot by the woods for about 5 days, seems that was plenty of time for squirrels to make a nest on top of the engine. Well about a mile down the road it caught on fire  here's a pic of the damage..  I picked up a new coil, wires and EVR. Looks like I still need all of the vac lines along w/ the 2 lines that goto the UIM (part #?). The main wiring harness is a little crispy too.. hopefully nothing melted on the inside.
Black E0 SVT
Posts: 1,456 |
Inspect those wires carefully. You must have had the car idling a while before the nest caught fire, to get that hot. Was the nest on the catalytic converters? What a pain..
Posts: 4,693 |
Depending on your insurance, this may be a covered event.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 3,788 |
Originally posted by Big Jim: Depending on your insurance, this may be a covered event.
True! Damn squirrels.
Posts: 1,746 |
Originally posted by LUCA: Originally posted by Big Jim: Depending on your insurance, this may be a covered event.
Damn squirrels?! How about poor squirrels...after all, all that he lost was a few hoses and wires...that poor squirrel lost his home, and winter is coming!!!
2000 Contour SVT
SF - #542 of 2150
Posts: 110 |
There is a 500 deductible and the damange is less than that.  The wiring harness for the coil is burned down to bare wires, you can see it in the picture, can I order a new one or is it tied into the main harness?
Black E0 SVT
Posts: 1,322 |
It may not be less than your deductable at a dealership. Have a dealer check it out.
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 5,882 |
Originally posted by Seth Green: Mmmm...squirrel
Posts: 496 |
Originally posted by mtxcontour97se: ... can I order a new one or is it tied into the main harness?
The coil connector and wires to it are part of harness # F6RZ-9D930-S6A list price $619.85. This harness includes the wires/connectors that run to the injectors, also the cam and crank position sensor, the ECT, IAC, TPS, IMRC, IIRC. I would inspect under the UIM and if the insulation of the wires are cracking, and you are under 100,000 miles get the harness replaced under recall M9903.
Posts: 110 |
Originally posted by eepals: Originally posted by mtxcontour97se: ... can I order a new one or is it tied into the main harness?
Where can I find more information on recall M9903? I am at 125,000 though..
Black E0 SVT
