TSB 00-01-05
TSB 00-18-02
TSB 94-20-10
TSB 94-22-08 Transaxle - CD4E - Fluid Leak From Pump Body Seal
TSB 95-02-07 Transaxle - CD4E - Coast Clutch Piston Seal - Service Tip
TSB 95-06-11 Transaxle - CD4E - Turbine Shaft Speed (TSS) Sensor - Mounting Surface On Pump Bodies Incorrect
TSB 95-15-08 Transaxle - CD4E - No Forward Engagement And/Or No 3rd Gear - Transaxles Built From 9/28/94 Through 10/30/94 (Serial #4271-0000 Through 4303-9999)
TSB 96-06-06 Transaxle - CD4E - Alignment Tabs On Transaxle Chain Cover Pan Assembly - 2.0L Probe 2.0/2.5L Contour/Mystique
TSB 96-08-08 Transaxle - CD4E - "Whistle" Noise At Operating Temperature, Engine Idling And Gearshift Selector In "Park"
TSB 96-09-05 Transaxle - CD4E Service Units - Low Automatic Transmission Fluid
TSB 96-14-11 cannot be color blind trying to follow this TSB Transaxle - CD4E - Engine RPM Above Expected Levels During 3-4 Upshift At Light To Moderate Throttle - High Impedance TCC Solenoid - Contour,
TSB 96-26-14 Transaxle - CD4E - Harsh Shift And/Or Engagement - Flashing Transmission Concern Indicator Lamp - Diagnostic Trouble Code 628 Or P0741
TSB 97-02-09 Noise - "Buzz/Vibration" In Reverse And/Or "Clicking" Noise Accompanied By Vibration On Right Hand Turns During Acceleration - Vehicles Built Through 1/6/97 With 2.0L Engine And CD4E Transaxle
TSB 97-04-06 Transaxle - CD4E - Harsh Shift And/Or Engagement - Flashing Transmission Concern Indicator Lamp - Diagnostic Trouble Code (DTC) 628 Or P0741
TSB 99-24-09 Transaxle - CD4E - Transmission Fluid Leaking From Transaxle Fluid Fill Tube Transaxle - CD4E - Transmission Fluid Seeping From Vent, Resulting In Fluid Collecting On Main Control Cover
Has any CEGer ever used this machine to have their ATX fluid changed?
"The TransServe�® II (Rotunda 211-0018) is a more effective way to change the transmission fluid and remove the old contaminated fluid in the system. The TransServe�® II may be used any time the transmission fluid needs replacement. "
Thank you.
U
U
I have been looking for this one ( http://www.performanceprobe.com/misc/tsb.php?article=99-24-09 ) forever!! I read about it in an issue of Gears Magizine a year or two ago, but since it was online and they change the links so often, I lost it.
Oh yeah... FYI, to everyone else. You might notice that all the links CPW posted are all redirected automatically by the Performance Probe site. You will notice that all the links, once redirected, point to the first TSB. If you notice this, don't jump CPW. Just go to the top of the page and redo the search. Everything will pop up from there.
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
Below I updated the links
TSB 00-01-05
TSB 00-18-02
TSB 94-20-10
