About a week ago my drivers side fog light went out. I just got around to going to the store to buy another 893 bulb. I replaced the bulb this evening and its still not lighting up.
I know it couldnt be the fuse because the two lights run off the same fuse, and the other light works. Despite that knowledge, I checked the fuse anyway. It's still good.
Anyone have any other idea as to why this is happening or did I just encounter a rare occurrence by buying a broken bulb?
00 CSVT Black/Midnight Blue 2.5L DOHC Duratec V6, 200HP, MTX-75 MODs: K&N Filter, SVT ovals, Autometer gauges, PIAA 510's, Alpine S-type FE/Pioneer R, Pioneer Premier Series reciever #603 of 2150 92 Cavalier 1.8L I4 (Beater)
F
F
Test the bulb with an ohm meter, open=bad, or swap to the other side. If good, you might have a socket corrosion problem. I had a wire corrode off my license light, due to trunk leak I think is (Now) fixed...
yea, use a test light to see if there is any power running to the socket. If there is, the socket must be bad. If there is no problem, and the fuse is good, then a wire might be corroded or broke from corrosion.
or an ohm meter
2000 Contour SVT SF - #542 of 2150
Alright, the bulb is good. it must be corrosion. Thanks guys
F
F
If the corrosion is in the socket, you might be able to clean/tighten the contacts and use silicone grease to preserve it.
