Posts: 7 |
i have a 2000 Contour SE 24V V6.. 29,000 miles on it.. really sweet huh! yeaa.. so anyways once i have about 120 miles after a fill up.. and ur at a complete stop, if u get on the gas really hard, the car just dives down.. and u have to let off and let her kick in then ur on ur merry way.. it rele sucks., say ur merging onto the highway.. and u need to get on it, u got people flyin past at 80, and all of a sudden ur car just dives down lemme tell ya its not a good feelin
Posts: 5,345 |
Fuel pump (try changing fuel filter first) or IMRC. Any CEL codes?
1996 V6 ATX 96K miles
Posts: 165 |
Originally posted by dschooniii: i have a 2000 Contour SE 24V V6.. 29,000 miles on it.. really sweet huh! yeaa.. so anyways once i have about 120 miles after a fill up.. and ur at a complete stop, if u get on the gas really hard, the car just dives down.. and u have to let off and let her kick in then ur on ur merry way.. it rele sucks., say ur merging onto the highway.. and u need to get on it, u got people flyin past at 80, and all of a sudden ur car just dives down lemme tell ya its not a good feelin
i had that problem when my fuel pump was dieing
do teh little things first like stated above,
also check ur throttle position sensor could also be a MAF
car has way to low of miles to be having problems,
1997 30th Anniversary SS,Jethotts/ORY/GMMG, 160thermo, ,TB bypass, 1LE intake elbow, BMR STB, 32mmswaybar..21mm rear,BMR LCAs, PR,SFCs,TA,LT4 KM,255lph, shift kit
Posts: 7 |
Originally posted by Tony2005: Fuel pump (try changing fuel filter first) or IMRC. Any CEL codes?
IMRC? whats that? CEL Codes?? what u talkin bout?!
Posts: 5,345 |
Posts: 5,345 |
From second link, I posted. Originally posted by Ray: Hey! Explanation......The engine has, as tony stated, what you can consider two "airways" it can use. one, when the secondaries are not opened, is comprised of about half of the possible airways being closed with small round plates attached to a rod.
The smaller total airway creates an increase in torque (to get you going). Once moving, the IMRC "does its thing" and pulls the round plates 90 degrees, allowing air to flow through the other half of the airway as well, thus doubling your volume and creating a surge in horsepower........
If your problem is a faulty IMRC, then it would never open the secondaries. This would exhibit symptoms of normal driving any time you are below the secondary operation RPM, but a loss of power (since it isn't opening those plates) at 4K (or so)..... Ray
