Posts: 50 |
Does the weapon r intake suffer from heatsoak like KKM? I was ready to spend on KKM but all the comments I read about is heatsoak. I'm afraid to put together a heatshield because I might mess something up. Some people are happy with the weapon r intake, so I might go that direction instead. I suffer thru traffic to and from work everyday here in Oahu  and it gets pretty hot so heatsoak would defintly be a factor with KKM. Any advice would be great. Thanks in advance
K&N Drop in Filter I don't know anything under the hood
Posts: 654 |
Im not sure, but if the Weapon R is the one that goes down to the air dam, theres more problems with it sucking in water... Heatsoak is not a problem with the kkm once you start moving a bit. I have the KKM and I would recomend it cause if i remember correctly, the Weapon R is like $200, compared to the KKM's $90 price tag. If your still worried about heatsoak, you can buy a heatshield for like $60, or make your own real cheap, its easy! Hope I helped a bit; Peace... -Nick
"My family hauler can kick your family hauler's @SS!" ~~~~1999 Contour SE Sport~~~~ -KKM True Rev -Custom cat back Flowmaster exhaust -All Cat's fixed. -SHO Shop Off-Road Y-pipe -Many other Mod's done...
Posts: 213 |
i have the weapon r intake, and i have to say that i do like this intake a lot and it has a real nice sound to it...havent had any problems with heat soak yet and i have had it for a year..
Posts: 1,355 |
Heat soak....what a bunch of crap! sorry, but it is in my opinion. Not saying that it doesn't happen, but not enough to hamper the performance. I mean, I live in one of the hottest places in the US, Las Vegas, and I have YET to experience heat soak. I would say get the KKM, its sounds and works great!
(Without the need for a heatsheild! :rolleyes: )
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 1,048 |
Anthony 98 black Csvt #630 of 6535
Posts: 1,444 |
i don't think the weapon r is the one that goes down. thats the sca intake. weapon r also includes the intake pipe in a polished look. thats why it costs more.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 50 |
I live in one of the hottest places in the US, Las Vegas, and I have YET to experience heat soak Sounds good to me... We don't get above 90s here. Thanks for the comments  I think I'm starting to lean towards the KKM again. I'll keep reading and do more research.
Posts: 1,090 |
according to a couple people on these boards, and based on their dyno plots, the KKM loses power at high rpm...
not sure if there's a better alternative though...
Posts: 1,812 |
weapon r would be subject to heatsoak just like the kkm is the weapon r filter foam? I've heard foam is a no-no. there are some simple simple heatshields around here (thecontourguy?), so don't eliminate that option. wonj - i've heard that, too.
lastly, welcome to the CEG boards!
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 3,248 |
Here is the data, Notice KKM flow much better than stock SVT (in LBM or pounds of air/min but look at the 30F increase in intake air temp. Each 10F rise in IAT cost you 1% or 2 HP on the SVT . That would be 6HP lost to heatsoak without a heatshield. Pretty much cancels out the 4-6 HP you gained from better flow. This applies to all open air filters on the Tour and you can expect Weapon R to be worse because in addition it has the aluminum airtube that will add more heat to the air. On my dyno comparison, conical K&N flowed just slightly better than KKM but only above 6000 RPMs - negligable advantage unless you plan on upping redline. KKM is a good choice as is BAT adapter + conical K&N, but get or make a heatshield. . http://contour.org/FAQ/misc/SVTvsKKM.pl
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
