I have two problems with my car.
Problem 1). My ABS light has constantly been on for three days. It came on two days after I drove onto a large pothole.(I don't know if that has to do with anything) I did a search and I read to check the fuses,ABS unit,pump,wheel sensors, and reset the computer. Where is the ABS unit and sensors located at? I want to check them out to see if I can figure out what's wrong.
Problem 2) When I am pulling out in Drive and I turn my steering wheel to the right sometimes I hear a rubbing noise while turning the wheel. What could cause that rubbing noise?
'98 Zetec ATX
'98 Contour Pacific Green(Modded) http://www.cardomain.com/ride/676416 FS:'98-00 Contour front bumper.Brand new unused (Non-SVT)
The ABS module is under the brake booster and the densors are on each rotor assy.
the rats are on the cheetos again Jet mechanic 98 silver frost SVT DMD Modified Intake First SVT to see the world Keenwood 10CD CHANGER, 12" JBL,4 CV
'98 Zetec ATX
Do you have upgraded wheels? Could be the tires rubbing on the splash shields for the fenders fi you turn all the way to the right.
If it sounds more like a groan, it could be low PS fluid.
The rubbing could be something as simple as the plastic inner fender not being fastened properly. Mine wasn't attached near the front bumper cover and it would rub. Reattached it and no more rub.
Not sure what to tell you about the ABS. Hopefully someone else on here can help more with that
1998 SVT. Silver Frost. #4076 of 6535. SOLD! http://www.cardomain.com/ride/2143175
