Posts: 65 |
hello membership ; i have read a variety of posts and have learned that EGR/IAC/DFPE/O2/IMRC? are common items of mechanical interest . from what i have surveyed , my problem may be related to spark plugs or wires ( or at the extreme , bad cat ) . ONLY IN 1ST GEAR DURING FULL THROTTLE , MOTOR CUTS OUT IN HIGHER RPM RANGE ! as if it cannot maintain the power during the rapid increase in engine speed . the mileage is low ; approx 50,000 american miles ! would the plug wires really be causing this , i guess i hope so as this may be the cheapest fix ? thanks for any comments and the confirmation of my solution !
Posts: 4,714 |
With that relatively low mileage, you may want to check the gap on the plugs before spending money on replacing them or the wires. The gap spec is .052-.056, IIRC. Regap any that are out of spec and try testing again.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 4,693 |
I think it is more likely to be plugs rather than wires. That is a classic symptom of worn or fouled plugs. Plug wire problems usually show up at lower loads.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 95 |
Describe in detail what you means CUTS OUT. Is this fully, partially, just missing? Any Codes? What RPM? It could be a fuel delivery problem but more info is required.
Posts: 25 |
With that amount of mileage could definetly be the beginning of the fuel pump problem. Try to identify if it is a continual problem or just when you have about a half tank of gas or less. Mine started a WOT and got worse as I had less gas.
Black/Tan 00 SVT
Do Tinted windows count as modified?
K&N
resonatorless (is that a word)
Yokohama Avid V4S 225/50/ZR16
Posts: 4,693 |
Originally posted by NavSVT: With that amount of mileage could definetly be the beginning of the fuel pump problem. Try to identify if it is a continual problem or just when you have about a half tank of gas or less. Mine started a WOT and got worse as I had less gas.
On re reading the original post, I agree. Somehow I was reading it as though you had a miss under load. It does sound more like fuel starvation. If it is new enough to have the returnless system, you need to search a bit and find out about the filter screen in the fuel pump module in the tank that plugs up too easily.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 65 |
thanks for your comments !
regarding the state of cut-out : power is completely missing for a second or two until it cuts back in and revs up to redline ! as stated , it is in upper range , power being absent from about 4500 to 5500 ! again , only in 1st gear !
and the most frustrating fact of all is NOT ON EVERY DRIVE ! only certain days ? i never run the car low on gas so that can be eliminated .
HOW MUCH LABOUR is it for mechanic to inspect fuel filter screen suggested in last post ? i will also have plug gaps checked at next service visit !
Posts: 4,693 |
If it were an ignition miss, plugs or wires, it would be a very sharp miss, very hard, for short duration, like a rapid staccato. If it is fuel starvation, it may come on suddenly, but it is still a bit softer and of much longer duration.
Jim Johnson
98 SVT
03 Escape Limited
