#1427266 11/02/05 04:32 AM
A little bored... I decided to read up on the contour and read other user reviews... I found this on the reliability reviews... "Occasional problems on this vehicle are failures of the Exhaust Gas Recirculation (EGR) Valve and the EGR Passages.The cost to repair the EGR Valve is estimated at $90.00 for parts and $65.00 for labor.The cost to repair the EGR Passages is estimated at $65.00 for labor.All prices are estimates based on $65 per flat rate hour and do not include diagnostic time or any applicable sales tax."
So... Since its a common problem, I was woundering... What is the symptoms of this valve failing? I have about 123K miles on my tour' and since this was a common problem, id imigine I migth be encountering it sometime in the future... Anybody have any ideas?
I may be relatively new, but I'll throw my two cents in.
What I've learned from the site (mostly from reading old posts from Ray or Big Jim) is that the EGR valve usually isn't the culprit.
The problem lies with the DPFE (Differential Pressure Feedback) sensor. It's a small, rectangular box that's kind of underneath the upper intake... I'm sure somebody will pop up with a picture for you. Somebody always does.
Anyway, since these things operate in a harsh environment, they're prone to failure.
Symptoms of a bad DPFE would be CEL (check engine light) codes for "EGR valve excessive at idle" or "EGR flow insufficient." Other symptoms could include worsening gas mileage, rough or erratic idle, and so on.
Simple test for the EGR (courtesy of Ray): The EGR is the silver UFO looking thing connected with reddish pipe at the back of the upper intake. With the car running, take the green hose off of it (careful! it's brittle as hell), and apply a vacuum (suck on it!). If the car stumbles, the EGR is functioning properly.
Also, it might not be a bad idea to pull the throttle body off the car and give it a cleaning, as well as the EGR passages (the cutout section of the TB).
Ah, go nuts. Do a complete UIM/LIM teardown and clean. There is a superb FAQ in the Duratec Maintenence section.
Hope that helps.
Damn, just read that you had the Zetec... my infor generally applies to the Duratec. My bad.
RIP 1997 Mercury Mystique LS - 2.5 L Duratec "Everything that's good is gone...." - Fuel
lol, its alright. But good source of anybody who is looking for EGR information, and props to you as a newbie for giving such good information for the duratec.
