When I hit bumps, cracks, etc there is a klunking sound coming from the drivers front side of the car. I have checked the Ball joints, and the tie rods, and they seem to be tight and solid. Any ideas what the noise may be? Thanks.
1998 SVT. Silver Frost. #4076 of 6535. SOLD! http://www.cardomain.com/ride/2143175
Could be splash shield (fender cover) or lower radiator deflector coming loose.
It sounds more "connected to the car" if that makes any sense. I will check those things though. Thanks.
Broken front spring? Hard to notice, since it usually breaks much higher/closer to the perch than usually/easily visable from the wheel-well.
a recall on that very item would indicate the possibility to happen, at least
Ray
F
F
Maybe the sway bar link is bad, it will clunk. Resembles vertical o---o , behind the cv joint/axle.
Yeah im going to have to say a sway bar end link, I need to replace both of mine
LCX Offline
Something else to add to the list would be a dead strut or possibly even the strut mount
Darn, I guess if it's the spring or strut I'll just have to start researching what new stuff I should put on my car and lower it.
Thanks for the input. I didn't know that there was a recall on the springs.
