I have a SVT w/ 205/55/16 Bridgestone Blizzak tires and it goes fine in the snow. I'd imagine that a non-SVT Contour may have a slight advantage in the snow due running narrower tires (I believe you can run 15's on the Contour for winter), but the manual tranny in the SVT may even the playing field a little by allowing 2nd or 3rd gear launches to control wheel spin. Hope that helps!
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue
Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
