Posts: 30 |
Im thinking of getting the sho y pipe (catless) that everyone is talking about. Does this mod really make that much of a differance? The sho pipe has a 2.25" inlet & 2.5" out. stock svt is 2.25". Also, the sho pipe will go back down to 2.25" to connect with the stock exhaust. I know that removing the cat will help a lot, but the pipe itself Im not sure. How much gain if any can I expect?
98 svt #3967/6535 BOD 10/13/97 itg air filter air inlet pipe south country strut tower brace A pillar gauge pod w/autometer Volts, Oil Pressure. and A/F Ratio Replaced resonator w/Dynomax Bullet
Posts: 407 |
If you find the car lacking in bottom end, get it! Out of all the mods I've got, this put the biggest grin on my face right away. Oh btw, I just put my cat back on - noticed no difference from the catless pipe.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 2,066 |
Posts: 81 |
I'm a fan of my yodude y-pipe,. but I recommend getting a hi flow cat...you'll find your car is much happiuer with the cat than without it.
1995 Probe GT ATX TOO MANY MODS 1999 Cougar V6 MTX Stage 1: (Basic Mods)B&M STS, Bassani Exhaust, KKM intake w/ weapon R pipe, ProFlow 75mm MAF w/optimiser, YoDude Y-pipe w/hi flow cat, SVT TB, SVT Upper IM, OMP FSTB,AF gauge, Aerogear fiberglass hood (completed) Stage 2: (Top End Work) 19-24lb injectors, P&P heads w larger valves and HPC coated, P&P and port matched lower intake manifold also HPC coated, custom ground cams, Ford Racing 9mm wires, Bosch +4 plugs, Custom burned PAC or Diablo chip (will dyno with both), Apexi SAFC (In Progress) Stage 3: (Transmission) Quaife LSD, CM stage 3 Clutch, Fidanza flywheel (In progress) Stage 4: (Suspension)Koni adjustibles, H&R springs, Progress 21mm rear anti sway bar (Installing on Tues) Current dyno: 172.9 whp with just bolt ons and stock exhaust manifolds (not gutted), oh, and bad wires  ...
Posts: 408 |
I ordered mine from sp motorsports about a week and a half ago. However, the pipe was not in stock. I called joe at sp and he said he finally got it in and it got shipped out yesterday. Should have it monday. If it gets delivered early, I might have it put on the same day. I also ordered the kkm. Can't wait, my first 2 mods. I'll keep everyone posted as soon as their both installed. I'll probably have a shop put on the y; " lack of tools and patience" But I'll put the kkm on.
vinny "2000 T-RED SVT" Mods: kkm sho shop off road y-pipe Audio: Alpine CDM 7874 Audio Control 4.1 EQ/Line driver Mb quart rsb 215 comp. Mb quart rsc 216 comp. blueprint 1001 sub 2 Phoenix Gold qx2180 amps
Posts: 70 |
yea..I think its worth it for the aluminized one...don't really need to spend the bucks for the stainless unless you really want it. worked..ok for me. I had slightly louder exhaust and felt a slight power increase. Worked good until it broke. I have a atx and the sho shop y-pipe wasn't designed for my drivetrain. My engine moves around way too much for the little flex pipe they put on the y pipe. So, the flange that connects to the catback completely broke off of the pipe and I had a very very loud car for a while. I'm either going to get it fixed and sell it or get it configured to work with my car...somehow
98 Silver Frost Contour SE Sport ATX BAT Handling Kit, SVT E1 Wheels, SVT TB, UIM, Airbox , SVT Exhaust, Rear Strut Brace, Pioneer Deck and 12 disc changer, Pioneer 6X8's
Posts: 1,812 |
love my ypipe...I highly recommend it. Merlin dyno'd 12hp and 6tq gain on his SVT (catless ypipe). At the wheels!! From the environmental side of me - get a cat
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 3,421 |
WTF this sucks this was going to be one of my next mods. I didnt know that there would be a problem with it on an ATX. this sucks. anyone else with an Atx notice this problem
Posts: 306 |
Originally posted by I-Dom-In-8:
WTF this sucks this was going to be one of my next mods. I didnt know that there would be a problem with it on an ATX. this sucks. anyone else with an Atx notice this problem Never, fear, I fitted the SHO Y pipe to me ATX with no problem. All I did was make a bracket to stop the engine pulling on the CAT and transfer any movement to the flexible coupling. I year later and 18,000 miles not problem. Check out the photos:- SHO Y pipe on ATX I can email you a sketch of the bracket I made if you like
Posts: 3,421 |
Hey man that would be awsome if you can. And thanks for the pics they will also help me out a lot. Kajork20@yahoo.com.. thanks again
