Page 3 of 3 1 2 3
Mobil 1 in EVERY vehical I own. I worked at a place that had free oil sampling and Mobil 1 was going 12,000 miles between changes and still had some life in it but CHANGE your filter Every 3000 miles REGARDLESS of what oil/oil filter you use. Pennzoil is Ok if you don't mind candle wax in your engine. the 12,000 + miles on an oil change was my Vortech supercharged 3.8L in my thunderbird and I DON'T baby it.
1996 Thunderbird LX 3.8L V6 with "bolt ons" -13.87 @ 98.9mph-
Thanx for the correction Rogerb. So, my consensus so far is to switch to synth-oil. Apparently "motor oil is motor oil" unless it is synth.
Pepse.
'95 Mystique LS Young America, Moonlight Blue, V-6 ATX, LOADED. REMEMBER: Always fasten your seatbelt as it makes it harder for the aliens to suck you out of your car.
O
ODC Offline
O
Originally posted by hot3dog3lucky3:
those who use mobil 1...how often do you change your oil/filter?
6000 kms = 3.2k mi
Mobil 1 + Ford OEM filter ...
hmmmm.. penz and parafin wax, nice buildup, ever since a lot of people hate it
I thought pennzoil and quakerstate were the same thing anyway? why would you switch between
99 Contour LX MTX, Cone Air Filter, Custom Grille 95 Neon ATX Intake, Ractive Muffler, Green Painted valve cover, fuel rail, and intake, b/w painted interior, white exterior trim, shaded tail lights
Penzoil is not the trash it was for many years. For that matter, all oils have improved greatly over the past 20 or 30 years. Penzoil uses the same process that Chevron does (they pay Chevron a license fee for it's use) It is also the same process as Texaco (owned by Chevron) as well as the same process used by Conoco (which also produces Phillips, Motorcraft, Union, and Kendall). Penzoil owns Quaker State and there is very little difference between the tow brands. Shell owns Penzoil. I don't know the composition of the current Shell product, but it has been traditionally a high quality oil. There is actually very little difference between any of the above oils.
The conventional (dino) oils have improved so much that there is no longer much difference in performance between conventional oil and synthetic oil. The main edge is in viscosity index range and extreme temperature use.
Actually, Mobil 5000 conventional is now using Group III base stock for their oil. Mobil does not recognize Group III as synthetic, but lost their lawsuit with Castrol over Castrol using Group III for their Syntec full synthetic oil. If Mobil 5000 had a Castrol label on it, it would be labled as a synthetic.
I too remember what trash Penzoil used to be, and still have a bit of a hard time in my mind about it, but being objective, it isn't bad stuff today. I'll probably still try to avoid it just from past injuries.
Page 3 of 3 1 2 3
