My son froze up his 1995 GL. I am pulling the engine to either rebuild or swap it. I have been using the Haynes book and am less than an hour away from being able to drop the engine. That is what they say to do, drop it out the bottom with the sub-frame. Then last night I saw that the engine rebuild sticky forum said he dropped it in the top?
Is it easier to go up or down?
I have always been concerned about taking out the subframe and getting it back in the same place.
What do you guys do (up or down)?
Thanks, Dale
1995 GL, 2.5L, manual
(love that clutch work)
1995 Contour GL 2.5
Do you have an engine hoist? Most go from the top.
#4559 of 6535 born on Feb 17, 1998 Black 1998.5 CSVT FOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
Engine only? top with a hoist.
engine/tranny? top with a hoist
tranny? well... I'd pull the engine and tranny out the top, still, but the tranny ALONE can come out the bottom.
Ray
Thanks!
Engine and trany, not sure which one locked up.
I was going to get an engine host and engine stand today anyway.
Are there other things (besides what Haynes says) that I have to do?
Do I need to pull radiator, I would think so?
Is it easy to pull the axles out of the differential?
Have a good one,
Dale
1995 Contour GL 2.5
E
E
No need to pull radiator. Just be careful when moving the engine past it. Axles pop out with a slidehammer after you disconnect everything.
** Mike ** "You might beat me in a straight line, but I'll embarass you in the turns"
It's a tight squeeze with a ATX or a MTX more so with an ATX, I've done both. If you can remove the upper intake manifold, cause if you don't you might bust the vacuum lines off. Motor and tranny together would be best!
It's a '95 GL, therefore a 4 banger. No UIM lines to worry about.
TDF, where did you find the I4 info?
his sig states:
, and even though he does state that his sons car is having problems, it doesn't (that I saw) state anything about an I4..
just wondering, was all.
Ray
It is a V6, not I4.
1995 Contour GL 2.5
Get a Ford Service CD. It's wayyyy better than the haynes manual. I'm sure if you search around someone might have a copy around...
2000 Contour SVT SF - #542 of 2150
