Posts: 363 |
My first instinct is that the VSS is dead. Here's the thing that confuses me. The cruise still works. I thought that cruise was controlled by the VSS. So if its not that, do I have a new cluster in my future ??
98 Mystique GS V6 - K&N, projectors
91 Mustang LX 5.0L
00 Jetta TDI, Yay, I bought it !!
95 VW Getta TD - RIP: Nov.3,2005
Posts: 5,345 |
ATX or MTX? Any other symptoms? CEL light? OD light flashing?
1996 V6 ATX 96K miles
Posts: 363 |
MTX, and apparently the trip as well. No CEL. This is an intermittant problem. Hasn't happened in a long time, but yesterday it died for 5 min, then came back alive. When things return to normal, the low fuel light will come for a few secs.
91 Mustang LX 5.0L
Posts: 7,100 |
Could also be a faulty ignition switch. I'd lean towards either the gauge panel connector (in the back) being iffy, or the vss sensor being loose (or wiring faulty), for your speedo/odo problem.
Ray
'99 CSVT - Silver #222/276
Posts: 363 |
Never had a CEL or OD light come on. Then its an MTX, don't think I'll see that puppy light up any time soon !!
Faulty ignition switch? How could that affect this? The car itself is fine ( motor still runs quite well ) I think I'll go look at the cluster first, then the vss to check the wiring. Since the problem is so intermittent, its got to be a wiring issue of some sort.
91 Mustang LX 5.0L
