#1420000 10/25/05 03:40 PM
SCSVT Offline OP
Well, thanks to all that have helped.
I have cleaned the throttle body and EGR passages plus replaced the DPFE. The response seems to be a lot better.
I unfortunately had another issue arise.
I am getting a very noticeable lag in repsonse when my RPM's are under 4000. It seems that the car doesn't want to move until the secondaries open. The car bucks a bit and when the secondaries open it is fine.
The rotten egg smell has almost gone away since the cleaning and DPFE replacement although I am unsure now if this may be a catalytic converter problem anymore.
Any suggestions?
#1420001 10/25/05 03:45 PM
Originally posted by SCSVT:
...I am getting a very noticeable lag in repsonse when my RPM's are under 4000. It seems that the car doesn't want to move until the secondaries open. The car bucks a bit and when the secondaries open it is fine.
Any suggestions?
Fuel Filter? Water in gas? (use HEET or fuel stabilizer), Dirty MAF sensor?
Edit. MAF. This thread might help.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=zetecmaint&Number=989728&fpart=1&PHPSESSID=
Fuel filter replacement.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=v6maint&Number=958655&page=0&view=collapsed&sb=5&o=186&fpart=1
#1420002 10/25/05 05:01 PM
I would start with cleaning the injectors. If they are slightly restricted they may be a bit lean under light load but seem OK under heavier load. If they are dirty, you will see an improvement under heavy load as well. I like Red Line SI-1 or Techron injector cleaners.
