Page 2 of 2 1 2
#1419897 10/26/05 04:35 PM
F
fomoco Offline OP
F
It's a 1997.
I don't know how to do the codes - theres no check engine - does that mean it's OK?
Anyone know if it could be a clogged cat or how to test?
#1419898 10/26/05 04:44 PM
"It's a 1997. I don't know how to do the codes - theres no check engine - does that mean it's OK?"
Take it to Autozone or Advance and scan it for free. No CEL could mean intermittent problem.
"Anyone know if it could be a clogged cat or how to test?"
For the Zetec.
A good cheap way to test for a blocked exhaust is to remove the O2 sensors, in this order (and see if the performance improves). Uninstall Lower to determine if main cat is plugged, reinstall lower and then uninstall Upper to determine if precat is plugged. Battery needs to be disconnected before uninstalling and installing O2 sensors. Good luck.
#1419899 10/27/05 01:43 AM
LCX Offline
Yeh let me know how you make out as your problem description is identical to mine.
I just cleaned out my MAF (which looked spotless to begin with) , still the same.
#1419900 10/27/05 03:47 PM
Could he have put the fuel filter on backwards?
1999 Mercury Mystique LS Sport 2.0L Zetec ATX
#1419901 10/29/05 10:05 PM
LCX Offline
Don't know about fomoco but my fuel filter is installed correctly
#1419902 10/29/05 10:57 PM
For the Zetec.
Uh zetecs don't have precats.
#1419903 10/30/05 01:08 AM
Thanks. Edited for accuracy.
For the Zetec.
A good cheap way to test for a blocked exhaust is to remove the upper O2 sensor, and see if the performance improves. Battery needs to be disconnected before uninstalling and installing O2 sensors. Good luck.
Page 2 of 2 1 2
