Posts: 5 |
Looking for recommendations for replacing struts on my SVT without lowering ride height. After searching posts here many seem interested in lowering ride height.
With the roads in the Northeast (CT) I scape front and rear ends now and then entering and leaving parking lots. Taller tires 225/50/16 KDW have helped quite a bit. After 135K on the original struts I think its time.
Thanks
Matt
1998 SVT 114,000 Miles
"I drive it silly"
Posts: 728 |
BAT Struts... Koni Struts.. KYB Struts..
all will be a major ride enhancement.. regardless if your at stock height or lowered...
if your looking for a slight upgrade to what you had originally I would go with the BAT struts...
Crispy
99 Cougar - Arancio Atlas/Grey Graphite Pearl Custom Widebody
98 CSVT - Silver Frost #4014/6535 - Born 10/21/97
98 CSVT - Silver Frost #4085/6535 - Born 11/10/97
See My Rides
Posts: 536 |
if your just looking to replace them with stock struts i have four slightly used svt struts id sell you.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 56 |
Go with KYBs if you are looking to keep everything stock.
...dating my cousin.
Posts: 21,197 |
KYB's?!!! NO! The factory strut is better than those POS's!
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 56 |
ALthough I agree that they are technically worse, I have found them somewhat comparable and cheap. I have also used KYBs in other cars and found them to be decent although not stellar.
IMHO, if you want to keep your car as a daily driver, without modifications and want the damper quality to match the age of your rapidly aging car, KYB's should be adequate and cost effective.
However, there are certainly better and more expensive options.
Posts: 9,602 |
Originally posted by todras: KYB's?!!! NO! The factory (SVT or early SE) strut is better than those POS's!
Exactly!
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 4,270 |
One word... Koni
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 4 |
Does the car ride lower than previously? Have you replaced springs? I had 3 of 4 springs crack. Typical problem, fronts were replaced under campaign for free. Back end was really low. Do you tow Hobie w/ SVT? I used to have 16 and towed w/ SVT now have Sea Doo - Need to sail again. I may be in market for Struts soon too, if you've seen my post on oscillation
Good Luck,
Brad
Posts: 5 |
Original Ride height, all original equipment except tires.
I have a Hobie 18, but I don't tow it with the SVT.
Matt
"I drive it silly"
