Posts: 7 |
Ok i have got my chip clean the pins put it in than didn't even start.I took it off no problem.Some of you guys told me that computer need to be shiped to superchips to get jumpers.I spoke with them and they are telling me the same thing.Now if I send this computer to them I'm not going to able to drive my car at least 3 days and also this is a 2000 car that I'm putting in jeopardy here.What would you do if you were me.Is this chip realy worth to have it.my car se sport atx,would it be a big difference if I put it.I wanted this chip to disable top speed limiter.Just need a little help here.would you send the chip back or send the computer and let them play with it.One more thing, my code is: VNM1 . does anyone have this computer with the superchip install.Just tell me the difference with it.and the box is a d type box.help!!!
------------------ 2000 SE sport Red,fully loaded.
Posts: 7 |
Posts: 1,664 |
from what I understand, the only Contours that are really worthy of the chip...are the automatics. Not only will it raise take out the speed limiter...but changes the shift points to a more agressive setting.
You may want to look in the FAQ's...i though at one point somebody wrote up instructions on what needed jumpered in the box...you may be able to do it yourself.
Joey 2000 SVT Black #1811 of 2150
Dad always thought laughter was the best medicine, which I guess is why several of us died of tuberculosis.
Posts: 610 |
i am wanting a superchip and also have a 2000 se sport once you get the info can you email me jessneric@peoplepc.com thanks
capitol ceg/southern maryland 2000 se tropic green kkn intake(will replace with svt soon), green interion lights(replacing with neons), pioneer 4100-no remote, fog light mod, svt exhaust, side markers, badgeless, 9005 instead of 9006(headlights will be replaced soon, pioneer 6x8 3 way(front) and 2 way(rear) need to istall-obx pedels 1999 se steel blue blue headlights and fog lights need to install sony cd headunit email-jessneric@peoplepc.com yahoo im-eric_j_linders aol im-ericsgreen00 msn im-ericsgreen00@altavista.com
Posts: 44 |
I am interested in chipping my 99 Mystique also. I didnt know i would have to send my computer to the company. That would suck. WOuld the chip make my car burn more gas. Right now my mystique is only 4 cylinder and the pick up sucks really bad. the chip would it make me take off faster.. Mike.. PS Jimmy tell me what happens.. Originally posted by Jimmy the Turk: Ok i have got my chip clean the pins put it in than didn't even start.I took it off no problem.Some of you guys told me that computer need to be shiped to superchips to get jumpers.I spoke with them and they are telling me the same thing.Now if I send this computer to them I'm not going to able to drive my car at least 3 days and also this is a 2000 car that I'm putting in jeopardy here.What would you do if you were me.Is this chip realy worth to have it.my car se sport atx,would it be a big difference if I put it.I wanted this chip to disable top speed limiter.Just need a little help here.would you send the chip back or send the computer and let them play with it.One more thing, my code is: VNM1 . does anyone have this computer with the superchip install.Just tell me the difference with it.and the box is a d type box.help!!!
Wine RedMercuy Mystique 99 Alpine 60x4 4 pioneers 6x9 kenwood amp rockford fosgate 10inch speaker in the processes of putting a superchip in
Posts: 445 |
IMO the chip is worth it on an ATX Contour.
I find it odd that your car won't start though. When I got my Superchip the first time, the car ran like it was running on one spark plug, but it started. At that point I sent my computer to Superchips so that they could pull the correct code from it. They sent it back to me with the reprogrammed chip the same day they received it from me, and I got it the next morning. I would try a little more with the cleaning and making sure the chip is in the computer tight. But sending the computer and the chip to Superchip is no big deal. If you can find time to be without your car for about two days.
------------------ Clinton '96 T-Red Contour SE V6 ATX
Clinton '96 T-Red Contour SE V6 ATX '01 Radium Sentra SE -Waiting for- '02 CD Silver Focus SVT
Posts: 3,223 |
FYI late '99 and '00 SVT's have to have their computer sent to superchip and have an jumper installed as well as the chip. The comuter module is different all together. I'm not sure if its the same for the other models but that would explain why your car won't start.
-Andy
------------------ -Andy Watson '99 Silver SVT #2397 205/55/16 KDWS Pioneer Premier 720 B&M Shifter, KKM EB Dyno Approved. If I weren't poor, so much more.
Posts: 7 |
I'm going to send my computer on monday and probably I'll get it back on wednesday.I spoke with All from superchips and what he told me was later model of contours need to have two jumper in order to communicate with superchip.They said it's normal car was not start.They guarantied that when they do the jumper it would be no problem.What I understand is this cars has Ignation cut off,and only way to start it it's your coded keys.My guess is when you install the superchip you can not access the code.thats probably they are jumping those pads to get it around.Its only my guess but when I try to turn it on with the chip I got nothing like your battery completely drained.thats got to be ignation cut safety future.anyway I'll keep you guys posted when I get the computer back.later.
Posts: 7 |
Posts: 2,631 |
Yes, the chip works, but it depends on the code of your computer. Some are positive gains and some negative. Check my sig's for dyno's
Merlin
281hp 324tq Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
