3 liter step by step flow chart:
1. Buy appropriate year 3 liter DOHC ('98+ if you're using your 2.5 heads, '01+ if you want a more direct swap.) If you're using '01+ block, skip to step 5.
2. Buy 3 liter head gaskets, buy the rest of the gaskets for the 2.5.
3. Disassemble the 3 liter down to short block. Short block in this case means block, crank, rods, pistons, and oil pump. Throw the rest away (including the oil pickup tube and 3 liter windage tray) or sell it to someone who wants/needs the parts. Several of the sensors can be kept as spares as several have the same part numbers as the 2.5.
4. Oil holes... Fill the bottom oil return passage at the rear of the block on both left and right banks using allen plugs and/or cold weld epoxy. There's an oil feed passage on the right bank of some years of three liters that needs to be blocked as well. Drill and tap this hole and top off with cold weld to ensure it stays.
4a. There's an extra mounting flange on the right bank of the 3 liter block (pre '01 anyway) that is not present on the 2.5 blocks. This must be cut off to clear the Contour alternator mounting area.
5.
ATX owners skip this step. Grind off approx 1/4" off of the transmision end of the crank to clear the MTX pilot shaft.
Measure yours first to be sure how much clearance is needed to remove enough off of the crank!!!6. If the block requires any machining (cylinders, crank, rods, etc), disassemble the short block to send off to machine shop. Reassemble to short block status once complete with machine work.
7. Shop manual. Need one. Assemble the engine using all of the steps in the manual. Both the three liter with the 2.5 heads and the full three liters with three liter heads need to use the 2.5 FEAD (Front Engine Accessory Drive IIRC). That means use the 2.5 front timing cover, alternator, power steering pump, etc.
8. Follow the shop manual's engine installation proceedure.
9. Go get a 3 liter ECU, 2.5 ECU with a chip, or a fuel/spark controller/s to be able to control the beast you've created.
10. Done
How much did this help anyone out? Not much I'd imagine, but that's all there is to it that differs from an instalation manual... Anyone feel free to kick in any steps I missed other than the implied 800 pound gorrilla needed to pry/stuff the engine in/out the top of the bay. Delete gorrilla if you have a lift and can come out the bottom.
