Posts: 2,156 |
okay i have had the Vortech on my Contour for the past 9 months. i am going to see if i can take action on something i have always been curious about. on my electronic fuel pressure i get it to read 58psi at max power. other S/Ced Contours are reading 80 to 100 on the guage. is this because i am using an electronic guage? i have the Phantom guage and i figured for the amount i payed it would be precise. or is there a problem with my fuel pressure. the a/f guage reads rich all the way through the rpm's. but it does sound like there is detonation after 5K. am i a retard or whats going on? cant figure out whats up.
Sam 1998 Contour SVT #180 1/4=14.2 @ 101.17MPH
AOL users = PhatSVT _ _ _____________ _ _
1986 Mustang GT 12 second club
Posts: 90 |
my friend had some problems with his electrical guage from them and ended up going to a mach. w/isolator.
the electrical he had never read right and also would show 0psi at idle but under the hood it would read 30 psi on a machanical guage on the fuel rail
all i need now is a lot of throttle and a whole lot of bottle
i wish i was a NitroFish
"3RD Pedal Racing"
Posts: 5,805 |
Go with a mech gage and consider upgrading your fuel line connections for the higher pressures.
Posts: 2,156 |
will do. i was told the mechanical is more reliable when it comes to the fuel pressure.
Posts: 5,805 |
Most electrical gages have two probs,delay in quick pressure changes and not that accurate.If you go mech try to get a 'filled' gage ,that is one with an oil or damping medium in it to stop the needle 'jerking'.
