Posts: 12 |
Hmmmm, 95 contour the 16V motor, ran fine then one day started it up and the engine idled very high, engine light came on. Now when I start it it does that every time...any clues??
Posts: 2,408 |
Could be a number of things.
Check the codes.
Posts: 1,788 |
The codes will likely point to the IAC.... or a vaccum leak.
Code retrieval instructions are on the FAQs off the Main Site (not the Forum FAQs...)
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 12 |
Originally posted by projectSHO89: The codes will likely point to the IAC.... or a vaccum leak.
Steve
Hmmmmm, took it to Autozone and because its a 95 model they said take it to the dealer...
How easy is the light pulse method I see on the main page, looks darn complicated for my skill levels
Posts: 135 |
I personally have never been able to get the light pulse method to work, including on other OBD-I vehicles... but that may be due to my own (lack of) abilities as well.
That said, an OBD-I scanner for your '95 is pretty cheap. Check out your local Sears and Autozone -- they usually run about $30 -- cheaper than the dealer diagnostic fee and plus you get to keep the tool. The OBD-II ones typically go for $100+, so on the prices alone, you can't get them mixed up.
Po
1995 Mercury Mystique GS: Zetec 2.0L I-4, CD4E
1978 Ford Thunderbird Town Landau: 351M (5.8L V-8), FMX
Coming in 2007 -- 1986 Jaguar XJ12 Sovereign: 5.3L High-Efficiency V-12, GM transmission
Posts: 1,788 |
The $20-$30 "scanners" still require you to count the pulses/beeps yourself.
A paperclip is still pretty cheap, it just takes some practice.
Steve
94 SHO ATX - 190K
Posts: 310 |
On a 95 it's simple. Take a paper clip / short wire stripped at both ends. Under the hood, behind the driver's side strut tower there are two connectors, a single and a second one that has i think 5 "ports" on it. Take your wire and insert one end into the single connector. Taking the second connector, orient it so that the 2 poles are on top (you'll see what I mean). Insert the other end of your wire into the top right plug and turn on the key.
Make sure you have it in park (out of gear) and the parking brake up at least one click to turn on the brake light in the dash cluster.
Follow your maintenance manual for how to count the flashes of the check engine light.
I'll put holes in him!!
Posts: 135 |
Whoops, my bad -- thanks for the correction. I stopped by Sears earlier this afternoon and upon seeing the OBD-I scanners realized that I had put up some misinformation on this thread this morning.
FWIW: AutoXray does have a text-based OBD-I scanner (linky) but it runs for $100.
Po
